Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
High RPM Hesitation
Old Aug 13, 2013 | 12:16 AM
Jab22's Avatar
High RPM Hesitation
I just replaced my spark plugs and cables on my 2000 Z28 yesterday and gapped them at .060 according to my owners manual. I know GM has changed the gap for spark plugs and all that stuff to .040. My car idles ok though. There has been hesitation since before I changed my plugs and cables and thought it would fix it. After I start to shift into 4-5-6 gear is when the problems occur and the car holds back until I give it full throttle, then it stops. Same thing is happening after I changed everything and the computer is saying it's either a misfire on cylinder #6 or a oxygen sensor which might make sense about the sensor due to the misfire on that cylinder. I am going to change that plug out for a new plug and see if it does the trick. If not what are your guy's suggestions? Any similar experiences?
Old Aug 13, 2013 | 09:07 AM
Re: High RPM Hesitation
What were the exact numerical codes?
jocamino
May 14, 2015 07:37 AM
ad356
Apr 11, 2015 08:49 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
IRABuss
Sep 7, 2011 09:08 PM
PhantomTA
Aug 17, 2002 12:19 AM
