Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Gas spewing from top of engine? 95 Camaro z28 auto. HELP
Old Apr 16, 2023 | 06:17 PM
SteveTejeda's Avatar
So I brought a z28 95 for 1000. The dude gave me a tranny with it. It also is sticking going from Second to third gear. But the major is the top of the engine when running it was spitting gas from up top. I’ve included a pic and video or try to put a video. Please help me guys I’m at a loss here
The gas will be coming from here. Is there a way to fix this or is something more trouble afoot?
Old Apr 16, 2023 | 10:09 PM
Re: Gas spewing from top of engine? 95 Camaro z28 auto. HELP
Is the fuel coming out the ends of the diagonal cross-over pipe on front of the fuel rails (part 3 in diagram)? Don't see a video.
If it’s the cross-over pipe, there are small screwed on brackets (parts 4 and 5 in diagram) holding the pipe to the rails, and O-rings (part 2) on pipe. Looks like the bracket on the driver side of the rail is bent up.
http://shbox.com/1/fuel_rail_94-97.jpg
First time in 25+ years on this site I've seen this problem.
Old Apr 16, 2023 | 11:13 PM
I would be the one special person to have this happen 😭😩🤣.
ha it’s coming out that cross over bar. It seems people are saying it’s the o rings. Would it be prudent to replace the fuel regulator while I’m at it?
thank you so much.
Old Apr 17, 2023 | 10:52 AM
Are you having problems with the fuel pressure? Would be due to the leak. Always best to test before replacing. I can give you the specifics for pressure testing. But that can only be done after the leak is fixed.
Old Apr 20, 2023 | 07:59 PM
I ended up replacing that o ring, the fuel pressure regulator and fuel filter. Does not do that any longer.
but now I found another problem that I’m going to post as well. 😩. This is becoming quite the project. Though I oddly like it. I seem to have found a wire not plugged in on the driver side where the adapter just fell off lol
darryle
Apr 4, 2017 09:27 AM
Custom_Camaro95
Oct 23, 2011 12:25 PM
Tyler0309
Oct 17, 2011 03:30 PM
algonyea
May 11, 2008 05:22 PM
z28racerf38
Feb 26, 2007 09:48 AM
