Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump testing
Old Apr 24, 2010 | 05:41 PM
94z28_08's Avatar
Fuel pump testing
This is a 94 z28 m6, full bolt ons nothing to fancy. Randomly this morning it wouldn't start. I went through the opti test procedure everything tests ok. I get spark. I can kinda here the pump come on in the tank like a small clicking noise not the normal run for 2 seconds and shut off. I gave the prime connector 12v nothing happens. I barely get any fuel out of the hose going into the filter. The relay is fine also. Is there anything else I can check. My fuel gauge also went nuts and reads way over full. I really don't to put another fuel pump in it if it isn't bad. This would be my 5th one. Any suggestions as to why my pump would burn up so quickly. I always fill up at half a tank and don't buy cheap gas. I'm using dephi fuel pumps. I know thats a lot but any advice would be greatly appreciated.
Old Apr 24, 2010 | 05:52 PM
dangalla's Avatar
5th pump? wow
how often are you changing pumps and is it for the same circumstances?
Old Apr 24, 2010 | 06:07 PM
94z28_08's Avatar
it is like every 6 months its getting old. The first 3 I had a shop do because I had to many other projects going. They were all done under warranty. The last 2 I have dropped the tank and did myself. Cleaned the tank both times to. I have never heard of a sending unit burning up a pump. But wouldn't doubt if its possible.
Old Apr 24, 2010 | 09:07 PM
The fact that the gauge went above full at the same time the pump died may be pointing to a problem with the harness connector above the rear axle.
Old Apr 25, 2010 | 11:05 AM
94z28_08's Avatar
yea that makes sense i'll check that out, thanks.
Old Apr 25, 2010 | 11:01 PM
94z28_08's Avatar
think I might have found one of the problems. the ground wire that connects from the tank and level sender is melted at the plastic connector on the sending unit itself.
Old Apr 26, 2010 | 06:14 PM
koolaid_kid's Avatar
I wonder what caused it to draw that much current? Is this an aftermarket pump, like a Racetronix or Walbro pump? If so, do you have the hotwire harness on it?
Old Apr 26, 2010 | 09:09 PM
94z28_08's Avatar
its a delphi, I'm going to run through all the wiring before I put it all back together. This thing was a mess when I bought it a couple years ago so god knows what I will find.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
