fuel pump problems
whats up everyone first post
i have a 95z28 that been acting wired car stalled would restart and stall again
i seen the fuel gauge went past the full mark so that tells me bad ground so i ground it to the body runs for a minute then stalls again i reground the wire to the original ground wire on the pump with a connector now it runs fine any thoughts as to what caused this ?did this solve the problem?or where to look to solve the car is stock except for exhaust and help would be helpful
thanks
thanks
thanks for the input and its a new fuel pump filter and relay
it did it again same thing ,regrounded just like before now it runs fine again very confused???? no service engine soon on not throwing any codes any info would be great thanks
sounds just like a crappy ground try cleaning the surface maybe its not getting a good enough connection.
If that doesn't work then try grounding it somwhere else but not to the body like 84firebird said.
i think i got it fixed the connector inside of the pump right on top looked real bad wiggled the connector and sure enough it did it again but i could not find the harness or bump assembly anywhere besides GM so i straight wired it and bypassed the bad connector and so far so good
thanks for all the input
