Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel pump noise?
Old Dec 27, 2009 | 04:09 PM
wbacall's Avatar
Fuel pump noise?
I have a 1994 Z28 with 250,000+ miles on it. The fuel pump is original. In the last few months it has started to whine or squeal when the fuel level is low and only as I am braking hard. The pressures are normal and the car runs fine. Anyone have any experience like this? I suspect I will need to replace the pump. Thanks.
Old Dec 29, 2009 | 08:17 PM
wbacall's Avatar
Anybody?
Old Dec 31, 2009 | 03:52 PM
maddog05's Avatar
Fuel pumps need to be cool
Our F body pumps last longer and run quieter when the tank is kept above half. The gasoline acts like a ice blanket on the submersed pump. Keep your tank reasonably full.
Old Dec 31, 2009 | 04:06 PM
MikeGyver's Avatar
The fuel pump is located inside of a 'bucket' which is always kept full by the return line, regardless of fuel level.
Old Jan 1, 2010 | 10:41 AM
bobdec's Avatar
I was thinking maybe the bucket could be messed up, but it really doesn't move around, and I've never heard anyone on the forums with that type of problem. In either case with 250K and a whining pump I think you'll be cutting a trap door fairly soon. Just for drill if it's the bucket let us know..
Old Jan 9, 2010 | 07:09 PM
wbacall's Avatar
Thanks! I will change the pump in the near future.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
