Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel pump issue with new motor
Old Nov 21, 2010 | 06:58 PM
speedracer2536's Avatar
So here is my prob.. pump wont come on with the key in the on position or when you try and crank it.. when i apply 12v power to the fuel pump prime wire it kicks on.. my car is a 94 z28 6spd.. I am also not getting power to the #5 fuse in the car that provides power to the fuel pump relay.. Does anyone have any thoughts on what this could be?
Old Nov 21, 2010 | 09:25 PM
Re: fuel pump issue with new motor
Does the pump run for 2 seconds when you turn the key from "off" to "run", and then stop?
Fuse #5 gets power from a pin on the ignition switch. Its the same pin that powers the air bag fuse (#1) and the gauges fuse (#9). Are the gauges working?
http://shbox.com/1/ignswschematic.jpg
Old Nov 21, 2010 | 09:41 PM
the fuel pump does not prime when the key is turned.. My gauges do work
RiverMutant96
Jan 30, 2015 09:21 AM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Perry93TransAm
Aug 20, 2002 11:23 PM
