Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel line help
Old Jun 29, 2015 | 12:50 AM
Tinoco559's Avatar
Fuel line help
I need some help identifying what gets connected on the short nipple on the fuel sender? I searched everywhere and can't find a thing.http://rs37.pbsrc.com/albums/e90/jt1...ap.jpg~320x480
Old Jun 29, 2015 | 08:20 AM
Re: Fuel line help
Line to fuel tank vent (pressure/vacuum relief) valve.
Courtesy of Shoebox
http://shbox.com/1/fuel_pump_wiring.jpg
PS: Please post a topic on only one forum.
Old Jun 30, 2015 | 04:58 PM
Tinoco559's Avatar
Re: Fuel line help
Ok thank you and sorry about that. I have a question I recently installed a new fuel pump cause I had to prime the pump at least 3 times for it to start after letting it sit for about 15 minutes or so. The new pump didn't help. Now I was checking the fuel pressure today and with the key on car off the Guage showed zero pressure primed it 3 times still same thing I turned on the car and Guage was reading 31 or 32 psi with vacuum and 40 or 42 without vacuum. As soon as I turned off the key the Guage read zero right away
Old Jun 30, 2015 | 05:42 PM
Re: Fuel line help
Rapid pressure loss when the pump shuts off can be:
-faulty check valve in the pump (replacement should have eliminated that possibility)
-leaking fuel pressure regulator (check the vacuum compensation line for wet fuel)
-leaking injectors (pull up rails with injectors intact, turn key to "run" to pressure the system. Look for dripping injectors)
-leaking fuel lines, including the flex pump discharge line in the tank (loose, or developed small perforations)
Old Jun 30, 2015 | 09:52 PM
Tinoco559's Avatar
Re: Fuel line help
Okay I found the culprit, it was the flex hose on the new pump, I added the old one to the new cause it didn't come with one, a new fuel injection hose and baym fixed. Thanks for the quick reply.
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
