Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
fuel issue
Old Sep 21, 2011 | 01:24 AM
Slinky96z's Avatar
fuel issue
so i am having an issue with my car starting. i mistakeingly ran it out of gas the other day. i put a lil gas in it to make it to the gas station. it started right up. i started driving to the gas station. i made it about 100 yards past where i ran out of fuel and it started to spit and sputter. i tried to start it again and it wouldnt start so i thought my fuel pump went out. i checked the relay and luckily the relay was blown so i replaced it and it still will not start. i had a friend say something about priming the injectors and that its a pain. i have read a couple other threads on here and i was wondering if it could be my opti.
any help would be great, thanks
Old Sep 21, 2011 | 07:38 AM
koolaid_kid's Avatar
Re: fuel issue
The pump is cooled by the fuel, so it is entirely possible that you burned up the pump. A couple of things to try:
When you turn the key on, do you hear the pump start up for a few seconds and then turn off?
Get a fuel pressure gauge and install it on the schrader valve at the back of the fuel rail. You should get ~40 psi when you first turn the key on.
Old Sep 22, 2011 | 10:21 PM
Slinky96z's Avatar
Re: fuel issue
Yes i hear the pump. I will try the pressure gauge on the shrader valve. Thank you.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Alex Barnes
Jan 24, 2015 10:21 PM
