Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Stumped by low fuel pressure
Old Sep 20, 2011 | 08:13 AM
pgerst's Avatar
Car ran very rich (barely passed CA smog at 15 mph (1261 rpm) with 58 ppm HC; smog guy suggested cleaning injectors. Also has hard start issue, harder when warm. Had 41 psi fuel pressure (ignition on, not running) though vacuum line smelled of fuel.
So I purchased a set of remanufactured injectors and FPR (Standard PR202) as well as a Racetronix fuel pump and wiring/ground kit. After I install the injectors and FPR, car seems to run leaner but now only have 35 psi fuel pressure (both priming and running). So I figure, fuel pump is bad (117K), replace fuel pump with new racetronix/walbro and then I only get 30 psi; replace wiring kit, small change to 33 psi. Removed fuel pump and everything is attached (added hose clamps to factory rubber lines just in case) and still only get low pressure (33 psi after several prime cycles.) If I remove the vacuum source, pressure will go to 40. Voltage at pump was 11.3v with factory harness and is 12.2 with racetronix harness; tested H20 temp sender with Tech 1A and is OK.
My thinking is maybe I got a bad FPR but why would I get 35 psi with the stock pump and 30 with the Walbro? Fuel filter is new but the car did sit for a few years, could it be plugged? What am I missing? Any ideas as I am stumped.
Old Sep 23, 2011 | 12:34 AM
OBE1 95Z28's Avatar
Re: Stumped by low fuel pressure
Fuel pressure is supposed to be 41 - 47 psi with the vacuum line removed; sounds like you're barely out of spec. Look here: http://shbox.com/1/4th_gen_tech2.htm...essure_testing
Old Sep 24, 2011 | 06:28 PM
pgerst's Avatar
I put a different regulator on and it is fixed. That's what you get when you buy the cheap one.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Cam's maro
Jan 30, 2015 09:21 PM
Alex Barnes
Jan 24, 2015 10:21 PM
