Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Emission failed. Please help
Old Sep 29, 2007 | 01:59 AM
mrmint69's Avatar
Failed emissions and it said car was running to rich. What do i need to do or check to fix this?
Old Sep 29, 2007 | 12:23 PM
Fuels94TA's Avatar
Well most common causes of running rich are.
exhaust leaks before the 02 sensors
bad 02 sensors
misfire
bad EGR
bad TPS
Also since your running a powerdyne has the car been tune?
Vinny
Old Sep 29, 2007 | 02:36 PM
mrmint69's Avatar
I got a code for a bad tps so it might be the problem. I replaced it right before the test and unplugged the battery so what do i have to do to reset it?
Old Sep 29, 2007 | 06:33 PM
Fuels94TA's Avatar
You might have to drive around a few so the pcm can adjust with the new TBS. Also what's your engine temp running at? I've notice when I run my fans at 160 the car runs rich. When I switch it back to stock setting it doesn't run that rich.
Vinny
Old Sep 30, 2007 | 12:30 PM
What were the exact test results for CO, HC and NOx, and what are the pass/fail limits?
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
BigWil
Mar 29, 2015 12:24 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
