Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
EFI connection LSX PCM
Old Sep 13, 2010 | 05:37 PM
bowtiepwr's Avatar
>has anyone tried this?
http://www.eficonnection.com/eficonnection/24x.aspx
Old Sep 13, 2010 | 10:34 PM
LT1 POWR's Avatar
A few on here have, do a search. I hope to have enough left in the budget to give it a try, should be a lot easier to tune as well as being "safer" to run at the limit on a FI application.
Old Sep 14, 2010 | 02:17 AM
ak95ta's Avatar
Yep, and I love it. Best money Ive spent on the car so far. I got one of the first kits, before they went to cnc on all their parts, but the quality is top notch.
Old Sep 14, 2010 | 08:11 PM
bowtiepwr's Avatar
>so what exactly do I need?
there seems like quite a bit of items... also using a Meziere electric water pump, so their timing cover is not required?
Old Sep 14, 2010 | 08:49 PM
ak95ta's Avatar
They can set you up with a package, you will be responsible for tuning. You can use your stock timing cover, unless you have a double roller chain. Im using my stock cover with a single roller chain.
Old Sep 14, 2010 | 08:53 PM
neil350's Avatar
Great set up, use as much GM parts as possible to keep it simple. Mike's customer service is bad ***
Old Sep 14, 2010 | 09:31 PM
funina91ss's Avatar
I am running one. On major advantage is being able to run a 4L80E trans.
Old Sep 15, 2010 | 03:11 AM
ak95ta's Avatar
I just noticed you have a 94 you will need a 96-97 front timing cover.
Old Nov 17, 2010 | 04:11 AM
bowtiepwr's Avatar
Re: EFI connection LSX PCM
>yes but I do have a 96-97 set up after the enging rebuild.
DirtyDaveW
Dec 1, 2016 05:37 PM
asilomar244
Jul 12, 2015 05:53 AM
KamikaZ28
May 28, 2015 12:45 AM
TT350
Mar 31, 2015 07:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
