Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Dtc 16
Old Dec 7, 2008 | 12:35 PM
lt1le2's Avatar
Dtc 16
Can a bad coil and icm cause a dtc 16?
Old Dec 7, 2008 | 12:56 PM
Not likely. DTC 16 is for the opti.
Old Dec 7, 2008 | 01:03 PM
lt1le2's Avatar
Dtc16
Shoebox I have been through like 5 opti's finalley i bought the Dynaspark opti for about 500 and my car runs for about 20 min and dies and sputters. Last week when i drove it it wanted to die and it stayed started but would barley go it was going in and out sometimes I would have to wait for about 3 hours to start it back up so the dynaspark lasted me about 1200 miles I am thinking there is something blowing these out I have no idea
Old Dec 7, 2008 | 01:22 PM
What part failed on the 5 previous Optis? Have they all produced DTC 16? Do you have any other codes showing?
Have you ever changed the harness, from the passenger side of the intake manifold to the Opti? Have you inspected it for corrosion or damage to the pins?
Old Dec 7, 2008 | 01:26 PM
lt1le2's Avatar
dtc
Its all been optical Sensors. The harness was replaced and then I bought a Dynaspark where the harness is built in I find it hard to beleave that all 5 opti's just go out like that. I dont know if i have a bad pcm or what but i am running out of ideas
Old Dec 9, 2008 | 05:27 AM
Guest47904's Avatar
Guest
If the 16 is consistent, you have an issue with the signal path from the opti to the PCM. Stop changing optis and start working on the wiring all the way to the opti. 2 connectors means you have 4 pins to mate together where problems can also be.
Old Dec 9, 2008 | 05:22 PM
lt1le2's Avatar
opti
Yea I am just thinking about buying a new PCM and i will trace that wire to see if there is any damage to it from the opti to pcm
Old Dec 9, 2008 | 06:38 PM
You also might want to verify that you are not getting excessive voltage on the red wire from pin B14 to the Opti.
Old Dec 9, 2008 | 08:49 PM
lt1le2's Avatar
opti
if it was getting excessive voltage on the red wire from pin B14 to the Opti what would cause that?
Old Dec 9, 2008 | 09:43 PM
I don't know... but its worth checking. Should be +12V.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
