Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Component Indentification
Old Sep 8, 2020 | 09:39 PM
1994-LT1-Eric's Avatar
Hey all,
This is under the fuel tank. What's the name of this component and its function? I found it once but can't remember now 😐
Thanks in advance,
Eric
Old Sep 8, 2020 | 10:48 PM
Re: Component Indentification
Fuel tank pressure/vacuum vent valve.
From Shoebox
http://shbox.com/1/fuel_pump_wiring.jpg
Old Sep 9, 2020 | 08:09 AM
From Shoebox
I searched yesterday and couldn't find this. Thanks Injuneer.
Ima go look up what this does, and how to check if it's working. Pretty sure mine is toast, original, and pretty brittle
Old Sep 9, 2020 | 08:20 AM
Simple valve that opens at 1 psi either direction it seems.
Old Sep 13, 2020 | 11:51 AM
The valve relieves tank pressure when it reaches 1 PSI. It relieves tank vacuum when the tank vacuum reaches 1 to 2" Hg. (0.5 to 1.0 PSI), per factory service manual.
Old Sep 19, 2020 | 06:53 PM
Yes, found it with a better word search!
Next time I'm home I'll test it!
-Eric
1994-LT1-Eric
10
Oct 10, 2019 09:13 PM
Defore
Jul 12, 2010 12:10 PM
Jason Short
Aug 24, 2009 06:25 PM
Jditlfm
Nov 25, 2008 06:31 PM
POTENTZ
Dec 7, 2007 03:07 PM
