Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
97 Camaro fuel pump relay chattering
Old Feb 11, 2015 | 07:59 PM
Scottyboy's Avatar
My son has a 97 Camaro that won't start. When I turn on the key just short of cranking the engine, the fuel pump relay chatters like a machine gun. Up until now if we kept trying to start it, the issue would go away after several minutes and the car would eventually start. however, I have not been able get it started for the past 2 days.
I did take it to a shop a couple of months back and they replaced the fuel pump relay. The problem went away for a couple of weeks, but the issue has returned. I don't want to spend a ton of money on it since I'm going to sell the thing so I'd rather try to fix this myself.
I am getting 12V at the orange wire on the relay plug, ground is good. But I am only seeing 9.6V-10V on the green/white wire when I crank the engine.
Could this be a PCM problem since I am not seeing enough voltage at the relay?
Old Feb 11, 2015 | 10:28 PM
GaryDoug's Avatar
Prominent Member
Re: 97 Camaro fuel pump relay chattering
Yes it could. But I would check the power wires coming to the pcm next. The pcm will run fine on only 10 v and you might not notice any other issues. Put the meter on each power wire (pcm battery and pcm ignition, 2 each) to the pcm while attempting to start.
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
blac94Z
Nov 24, 2014 07:12 PM
Carson96Z28
Aug 28, 2002 05:23 PM
Skull Leader
Aug 10, 2002 11:01 AM
