Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
95 camaro lt1 will not fire
Old May 9, 2015 | 09:01 PM
Michael Roberts's Avatar
ok guys I have ask so many people but no one can help me out I just had my motor rebuilt and got it all back in the car but now it will not fire and I put everything back new but the computer it ran before but now it will not hit a lick new opti new I my new coil new plugs and wires new everything lol what should I check or where should I start o and I have power to my injectors but that don't have full coming out of them
Old May 9, 2015 | 09:03 PM
Re: 95 camaro lt1 will not fire
But the car will not fire and it has a new Icm
Old May 9, 2015 | 09:04 PM
What's the odds of the computer going out just setting
Old May 9, 2015 | 10:25 PM
Have you scanned it for codes? Have you checked the fuel pressure?
Old May 9, 2015 | 11:32 PM
Just put in a new fuel pump and I checked the power going to the coil and opti I have power to the coil and I have power to one wire on the opti now I don't know what wires should have power or anything like that but I did check to see if any f them had power and that had 12.34v on them and it's grounded good
Old May 10, 2015 | 02:18 PM
There are codes for faults in the ICM and Opti. The ones for the Opti don't turn on the SES light. There is a procedure for checking the signal from the PCM to the ICM. See the "sticky" on top of the "LT1 Based Engine Tech" forum, or shbox.com. That's important because that signal originates from the Opti.
liamcg97
Nov 25, 2019 05:55 PM
Noenav
Mar 1, 2019 07:38 AM
nophix
Nov 30, 2014 10:26 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
