Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
94 lt1
Old Mar 16, 2008 | 07:00 PM
  #16
23tigga's Avatar
What is the correct idling rpm for a 94 lt1
Old Mar 16, 2008 | 07:14 PM
  #17
2000GTP's Avatar
With the engine fully warmed up, for an A4 transmissions, in neutral 650rpm and in drive 550 rpm. An M6 is 800rpm.
Old Mar 16, 2008 | 09:24 PM
  #18
23tigga's Avatar
Where is the fuel regulator located on this car year and can it be manually adjusted
Old Mar 17, 2008 | 12:44 AM
  #19
ak95ta's Avatar
its on the back side of the drivers side fuel rail. If its the stock one, it can't be adjusted.
Old Mar 17, 2008 | 07:54 AM
  #20
23tigga's Avatar
so since it is stock i would have to change the whole thing out or can it be adjusted with an computer?
Old Mar 17, 2008 | 08:03 AM
  #21
2000GTP's Avatar
Its controlled by vacuum, not by the computer. Why do you want to change it, is it bad?
Old Mar 18, 2008 | 10:10 AM
  #22
23tigga's Avatar
i believe so because my car is not burning enough fuel and i pulled my spark plugs out the other day and they have black sutt on them and the plugs aren't even two months old. a mechanic a chevy told me it may be my regulator going bad to start their first so thats why im asking about this specific part.
Old Mar 18, 2008 | 12:49 PM
  #23
2000GTP's Avatar
The way you are describing the plugs, it sounds like the car is running rich. As for the fuel pressure regulator, there is a vacuum line that goes to it. Pull it off and see if there is fuel in the line, if so, then the fuel pressure regulator needs replacement. Also, it wouldn't be a bad idea to do a fuel pressure test on it.
Old Mar 18, 2008 | 01:19 PM
  #24
23tigga's Avatar
what could be causing the car to be running rich. Im not familiar with this type of activity
Old Mar 24, 2008 | 08:05 PM
  #25
23tigga's Avatar
someone please help me locate the problem to why my car is running rich! please!!!!
Old Mar 25, 2008 | 10:06 AM
  #26
-faulty O2 sensors
-faulty O2 sensor wiring
-exhaust leaks before the O2 sensors
-excessive misfires
-excessive fuel pressure
-leaking fuel injectors
-leaking fuel pressure regulator
Before you do anything, check your fuel pressure. Should be in the range of 41-47psi at idle, with the vacuum lined off the fuel pressure regulator. You started out asking about the fuel pressure, and the regulator. It was suggested that you check the vacuum line. Did you check it, and what did you find? Its very hard to help you if you don't follow up on suggestions.
Old Mar 28, 2008 | 10:56 AM
  #27
23tigga's Avatar
no i haven't checked it yet just got over a bad cold but as soon as i get home i will look for possible suggetions sorry for the delay in updates
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
