Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
'01 3.8 won't start!
Old Mar 10, 2010 | 12:18 PM
El Guapo's Avatar
I have a 2001 3.8 Camaro that I JUST bought a week ago and they day I went to look at it they said it wouldnt start because of the fuel relay, since then it hasn't started on 2 different occasions, i've checked all the fuses and relays and they all work. I've also banged on the gas tank to try and jump the fuel pump and it still wouldnt start. The fuel pump also doesn't make the usual sound when you turn the key over. I've read it could be the charcoal canister or the EVAP line, is this true and how do I fix it? Thanks.
Old Mar 11, 2010 | 04:58 PM
You've already got this on the "General 67-02 F-Body Tech" forum. Post only once, and only on the correct forum.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
