whats the max hp 50# injectors will support?
Originally posted by mehoffz24
so all you guys are saying that if i make 550rwhp or so that the walbro 340 and 83# injectors will be over kill , and will be fine if i ever wanted to upgrade anything to run more boost. when you using the stock regulator how do you adjust the fuel pressure, throught the pcm? thanks for all the GREAT info
Rich Krause
83's will be fine. I just got done tuning mine on the WB O2 with 83's. I had the PE tables at +48% and A/F ratio was pegged rich. After backing off a bit on the PE, the A/F is now ~11.1/1 with the combo in my sig. at 13 psi boost.
The 340 will be marginal, perhaps not enough pump. A volt blaster / Boost a pump would make it work, though.
Mike
Mike
ducttape1975
Jul 10, 2015 06:29 PM
