What's a BRAND NEW D-1SC head unit worth??
Old May 31, 2007 | 05:36 PM
  #16
Fastbird93's Avatar
Originally Posted by Jeff 96 SS
The biggest reason people can't make boost is inneficient piping! Both the intake side of the blower and the output to include the IC. if you want 20#s out of a D1 run pipe direct from blower to the TB and run alky in place of the IC I gaurante you will pick up at least 4#s. Or spend big dollars on custom piping and custom intercooler. The kits you buy are for street cars not race cars so they are very inneficeint. Crappy heads have an effect to but not near as much as what people think. Jeff
FMIC for me is out of the question as I'm not willing to cut up the nose of my Trans Am nor am I willing to delete the fog lights. Just not efficient enough sitting there behind everything (although Call 911's seems to be doing good and his setup probably has about the same flow as my T/A would). I have put though towards doing a Blower to intake direct pipe since I'm going to be running injection anyway, but haven't decided for sure yet as I'm curious what my motor is going to do with the way it's set up. Main goal is to get everything in and running. I can change intercooler and piping up after the fact. Seeing D-1SC results recently on a 383 LT4 headed setup making 680 RWHP without meth through twin intercoolers gives me hope though.
Originally Posted by Ponyhntr
To run an F1A you should not have to delete the ABS... it is the same physical dimensions as the D1SC.
A member on another board informed me of this. Thanks for the confirmation!!
FYI the setup is 383/LE ported TFS Heads/LT4 manifold, so it should move some pretty good air.
I've got feelers out about a head unit exchange at the shop I purchased the blower from and a couple of other places, so hopefully something there materializes.
Thanks everyone!
Old Jun 1, 2007 | 09:36 AM
  #17
92LT1RS's Avatar
then I'm more than interested to see what kind of results you get as I'm also doing ported Trickflows, however I'm going with a ported LT1 intake instead. good luck with your build
Rod Bender
Jan 1, 2015 03:18 PM
screaminss
Sep 4, 2002 12:48 PM
slothgrant
Aug 22, 2002 03:01 PM
Brian Demeter
Aug 21, 2002 02:07 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
