Whats the best headgasket for a boosted car?
Old Nov 19, 2007 | 07:26 PM
  #16
jmangler's Avatar
thanks for the tip
Old Nov 19, 2007 | 08:24 PM
  #17
rskrause's Avatar
Moderator
Cometics and similar MLS gaskets leak/seep ~1/3 of the time they are installed. They are about 2X as expensive as the #1074. If you blow a #1074 there is something seriously wrong with your setup which is causing significant detonation.
Rich
Old Nov 20, 2007 | 10:35 AM
  #18
mzgp5x's Avatar
I run FelPro 1074. I torque them 3 rounds when installing. Let them set/ relax Ovr_night, then re_check . I too have ditched the stock fans. Went with two flex-lite low profile 12". Had to custom mount fans to the be_cool rad. Also moved the rad forward by mod of the front mtr_comp rad steel (available room is quite nice and very maintenance friendly). With LT1 _edit, I run my fans constant. B. (97ss 383-D1)
Old Nov 20, 2007 | 11:08 AM
  #19
jmangler's Avatar
Rich
wow, I didnt know that. I dont need no head aches so I will go with the #1074.
I will look into that fan set-up. thanks for your input. its the second time I blew a fan fuse and I dont want it to happen again so I definately want to change the set-up. My fans are almost canstantly on so thats why the fuse takes a dump on me every once in a while...
Old Nov 20, 2007 | 01:17 PM
  #20
97WS6Pilot's Avatar
Felpro 1074's here.
Old Nov 23, 2007 | 11:32 AM
  #21
BIGCATPOWER's Avatar
Felpro 1074 + 22psi Boost. I Would Rather Replace The Gasket Than A Piston!
Old Nov 23, 2007 | 05:29 PM
  #22
Lisa33's Avatar
I have replaced 3 pistons, no 1074
Old Nov 23, 2007 | 10:56 PM
  #23
SiDeWaYZz28's Avatar
can you reuse cometics?
Old Nov 24, 2007 | 06:33 AM
  #24
97s10ondubs's Avatar
yes
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
Burn_Out
Aug 18, 2002 08:49 AM
