what kind of crank pulley/ balancer are you guys running?
now that im geting this engine together i want to buy a new balancer. should i go with a oe replacement or aftermarket. WHAT would be the best choice. im running an eagle balanced rotationg assembly, mcleod steel flywheel and a d1sc 15# pulley. should i buy the expensive ATI balancer or will stock be just fine for that i want to do. i dont think ill have a problem with the stock one because everything is balanced but since you guys have the experience im open to all sugestions. thanks
If it's a street car, I'd probably clean and coat the stocker and call it a day. The ATI balancer is a nice piece, and it's SFI approved to like 8 seconds in the 1/4 or something. If you've got a spare $400 bucks, go ahead and get the ATI.
same here with my fluidampr. cracked at the keyway. if you are gonna spend the money on the ATI, you may just have em send you the custom BBC OD ATI custom balancer. ID is SBC but OD is BBC. 5 times thicker hub for strength where most crack. about the same cost i believe and is most blowproof. lots of stress on the keyway groove with a big blower application. would require some mod to the cover for BBC seal. not a big deal though. just a thought for some added stability (especially if you are not double keying). lots never have problems, but if your gonna spend the $$ get the thicker hub. just my 2 cents.
mike
mike
thanks for all the replys guys, i dont plan on reving past 6200 anyway. i think i will just buy a new stocker and call it a day. can i just buy the keyed hub from thunder racing and use that with the eagle crank?
http://web.camaross.com/forums/showt...threadid=94281
http://web.camaross.com/forums/showt...threadid=94282
http://web.camaross.com/forums/showt...hreadid=202609
--Sean
