At what boost level are 6" rods going to be too long?
Old Jan 4, 2004 | 11:23 AM
LameRandomName's Avatar
The conventional wisdom says that with the deck height in the LT-X motors, running a 6" rod pishes the rings so far to the top of the piston that the top land is a reliability issue under boost. (or nitrous for that matter)
Presumably, 2 pounds of boost would be a non-issue.
By the same token, 20 pounds would be a serious concern.
This begs the question; at what boost level does a 6" rod and it's corresponding spring pack issues become enough of a reliability concern to warrant moving down to a 5.85"(or shorter) rod?
I know there is no hard and fast answer to a question like this, but that's OK. Educated opinions and bitter experience are fine by me.
Old Jan 4, 2004 | 12:50 PM
rskrause's Avatar
Moderator
Like you said, no hard and fast rules.
Rich Krause
Old Jan 4, 2004 | 03:07 PM
Just trying to learn from the mistakes of others.
I'm cheap that way.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
drptop70ss
Mar 26, 2015 01:50 AM
