Vortech S-trim
Old Sep 27, 2006 | 02:03 PM
  #16
rskrause's Avatar
Moderator
Re: Vortech S-trim
Originally Posted by engineermike
The compressor cfm is based on some boost level. Obviously, the more air the engine flows, the lower the boost will be, the higher the total flow will be. LJ's 140 mph at ~3750 lb indicates nearly 800 fwhp from an S-trim. Conversely, I was only able to run 133 mph at the same weight with a T-trim running the same pulley ratio as he was. That indicates I was only making about 680 fwhp.
Take a look at a compressor map for the S-trim.
Regardless of boost pressure, 1,000cfm will not produce more than ~650-700hp in a typical 2-valve OHV V-8 and will usually produce less. If you try to spin the SC faster, you will heat the air more and take more power to drive the impeller. The result will be more boost pressure but less hp. You made less hp with a higher output blower due to a lower VE. As you suggest, your boost was probably higher. Another way to look at it is as follows. What do you think would happen if you put an S-trim on an NA Pro Stock motor? It would decrease horsepower and would decrease manifold pressure (increase vacuum), not increase it! This is because the motor is already moving far more than 1,000cfm, probably in the range of 2,000+cfm.
I don't know anything about LJ's combo, but he must have some awesome heads, etc. to get that kind of hp out of an S-trim. I stand by my generalizations non-withstanding. An exception does not negate the rule.
Rich
Old Sep 27, 2006 | 03:00 PM
  #17
engineermike's Avatar
Re: Vortech S-trim
It would make way more than Vortech's rating of 650 hp and 1000 cfm.
Notice on Vortech's compressor map that they did not run the compressor all the way to stonewall. Based on the curves, and the fact that none of them nosedive, stonewall is probably around 85 - 90 lb/min, which equates to way over 650 hp. I think that their rating is more of a fuzzy "what most people can expect" number.
Mike
Old Sep 28, 2006 | 07:45 AM
  #18
flusz28's Avatar
Re: Vortech S-trim
Blown69nova - my s-trim only has 2,000 street miles on it. what are you going to do with your Procharger? interested in some kind of trade/deal? i like the noise they make. my s-trim is the newer design and has the quiter gears in it so you only hear a little whistle.
Old Sep 29, 2006 | 10:36 PM
  #19
EDS Z28's Avatar
Re: Vortech S-trim
The compressor map doesn't take into account intercooling. I think the S-trim has way more potential than people think.
If you want a quiet unit, the V2 S-trim would be perfect. It should be able to run tens with a nicely built motor. It is capable of 680 hp per vortech, but this is only on paper and no intercooler. I have this blower and it has performed very well. FYI, you can hear it, it's not silent.
The other supercharger unit I thought of is the Paxton Novi 2000. I think it's too big to fit in the f-body engine compartment, and they never offered an f-body kit, so you would have to fab up a custom bracket. The mustangs run these.
RUENUF
Mar 13, 2016 03:37 PM
TimChiaretto
Sep 1, 2002 11:29 AM
Frun
New England Area
Aug 28, 2002 07:08 PM
BOOST FED 95Z
Aug 25, 2002 04:00 PM
