Twin 76mm on a LT1?
Old Oct 10, 2011 | 09:32 PM
Chainsaw_Camaro's Avatar
Twin 76mm on a LT1?
Has anybody ever put twin 76mm on a lt1 before? I am sure that turbos that big would be more than any LT1 block could handle if you really pushed them. I am just wondering how a 383ci motor would spool the turbos. I have 2 PTE 76gts turbos with the .96ar. I just wonder if they would lag to much and not spool well. Any thoughts? I already have most all the parts to put this together. It is going to be my winter project and I plan on making a build thread with lots of pics if I go through with it.
Old Oct 11, 2011 | 07:13 AM
DirtyDaveW's Avatar
Re: Twin 76mm on a LT1?
Tiago in Houston put two 76mm on his street purposed LSx T/A. It reputedly puts out about 1,300hp. It murders his transmissions. I think the last time I spoke to him, he'd killed six T56 transmissions. He now has a purpose built TH400 but it's a tough compromise to have a street car in the expanses of Houston (normal commute from one side of Houston to the other on the tollway is still 45 minutes with no traffic!) that uses a transmission without an overdrive. Big Rick(another Houstonian) put a 90mm on his T/A LT1 that went 8's in the quarter in bad air (High humidity) so the LT1 can hold it fine. All an LT1 is , is a SBC with Reverse cooling. It has no more inherent weakness than a traditional SBC and those things have run astonding HP for decades.
Keep us posted on your progress. I know it's an excess to have that much HP on the street but that's why we all wish we could do it
Old Oct 11, 2011 | 08:03 AM
This is true, LT1s are just not much more than a traditional SBC. If I was going to build a old school small block I would have the option of starting with a stronger aftermarket block. I just wonder how much a factory block will take. I am also wondering if the 76s with a .96ar will be to much to spool quickly. From the research I have done it seems guys with 350+ cubic inches tend to run a .68 or .81 ar for a faster spool. I guess I will just have to try it out and see how it does.
Old Oct 12, 2011 | 01:30 PM
MikeGyver's Avatar
A 1500+ hp 383 would spool two 76mm turbos just fine.
Old Oct 12, 2011 | 08:59 PM
Kevin Blown 95 TA's Avatar
OK but you wouldn't have the 1500 hp unless you were able to spool up the two 76 mm turbos
he should add a 300 shot of nitrous
Old Oct 14, 2011 | 12:34 PM
RealQuick's Avatar
Track only car?
Old Oct 16, 2011 | 10:03 PM
MikeGyver's Avatar
You'd need an extreme motor to actually use two thousand-HP turbos.
Your average built-383 would take like 30psi of boost to get there...
Possible? yes. Completely ridiculous? yes.
Old Oct 17, 2011 | 05:29 PM
Originally Posted by RealQuick
Track only car?
No its a street car, and the system is actually one of your single 76 kits modified. There is no way I am going to be able to push these turbos to their maximum capability. I just want more power than a single 76 can give so why not slap another one on there?
Old Oct 17, 2011 | 05:33 PM
Yes ridiculous, but wouldn't a potentially 8 second street driven LT1 be sweet?
Old Oct 17, 2011 | 07:31 PM
RealQuick's Avatar
Hmm... interesting! Which kit of mine do you have?
Old Oct 21, 2011 | 02:18 AM
97WS6SCharged's Avatar
Personally I would look into selling the 76s and stepping up to a single T6 in the 90mm+ range.
Old Oct 21, 2011 | 04:55 PM
Single 76 header kit. I used to have another name on here. I never got that build finished because I got laid off from work. Now that I have a new job and am starting to get back to work on the car, all my friends are way faster. Now I have to try and play catch up. That is just life I guess.
Old Oct 21, 2011 | 04:58 PM
Yeah I thought about that. I have a few friends with big 90mm+ singles. Wicked cars, but I have always wanted to say I have a twin turbo camaro.
LeftoverChinese
Jan 14, 2024 03:03 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
