Turbocharger cams?
Old Jan 24, 2004 | 11:55 AM
Rodrigues's Avatar
Turbocharger cams?
I am getting a twin turbo setup and right now i have a 230/236 cam on a 112 lsa, would it benefit me greatly to get a turbocharger cam with less split? Also, how do GT28 turbochargers compare to other turbos out there? They rate them at 350 max hp each, is this at the flywheel or rear wheels?
Old Jan 24, 2004 | 09:12 PM
blueta's Avatar
A tighter LSA will benefit you because you won't lose so much boost. Also a cam with less duration wouldn't hurt because there is more overlap with a bigger cam.
Old Jan 25, 2004 | 02:56 PM
Wild1's Avatar
check out Combination Motorsports
Old Jan 27, 2004 | 11:32 AM
mn_vette's Avatar
Cutting down the duration will help so you don't have as much overlap. I believe the equation goes ((Intake + Exhaust)/4 - LSA) *2 = overlap @ 0.050
So you've got 9* of overlap. The way that it was explained to me is that the pressure in the exhaust headers is usally greater than the boost created so when you have overlap you get exhaust blowing back into the chamber and slowing the incomming air down.
Old Jan 27, 2004 | 11:35 AM
Wild1's Avatar
Your typical turbo cam has 114 LSA... Less overlap is better for any boost vehicle. The primary difference between the turbo and blower cam is that the blower cam needs longer exhaust duration.
MN_Vette said it correctly, overlap is bad for boost.
Old Jan 27, 2004 | 04:23 PM
SantaCruz163's Avatar
Is 8* of overlap too much for hi performance superhcharger setup (D1 Procharger). I was looking at some of C Motorsport's S/C cams and a lot of them had around 8* of overlap with that fomula.
Old Jan 27, 2004 | 05:42 PM
Wild1's Avatar
I can't really say... define "too much". If you live in Cali, yes too much would make you fail smog.
Also, most Dynamic Compression Ratio calculators use the Advanced Duration. With that in mind, about 50-52* of overlap is about the limit. The problem is that Advertised Duration may vary 0.003 between manufacturers. The reason for AD is that the compression bleeds and builds the moment the valve lifts from the seat.
Measurement of 0.050 are more consistant for an industry standard, however are too sloppy for any DCR calculator I've ever used.
rideordie
Nov 5, 2019 04:52 PM
NewsBot
May 15, 2015 10:10 AM
cmsmith
Apr 11, 2015 09:37 PM
Brady
Nov 13, 2002 11:05 AM
Brady
Jul 29, 2002 10:30 PM
