Troubles on the dyno- come in and help a brother out!
Old May 2, 2010 | 06:17 PM
slowZ's Avatar
was at the dyno and had some trouble making power past 48-4900.
I now have a rear mount tc-78 @ 7lbs.
Heres a dyno sheet, let me know what you guys think is going on.
Old May 2, 2010 | 09:32 PM
reamo04's Avatar
hows ur valve lash look? Seems like floating valve springs perhaps.
Old May 3, 2010 | 09:14 AM
slowZ's Avatar
Valve lash is 1/2 turn past zero lash. that's what i am thinking also, i had the springs checked and they are still good (specs close to when they were new) but possibly need shimmed for more seat pressure.
Old May 3, 2010 | 09:51 AM
cause4panic's Avatar
Whats your plugs gapped to?
Old May 3, 2010 | 11:27 AM
slowZ's Avatar
they were .032 but i put in new ones gaped at .028
Old May 3, 2010 | 11:54 AM
reamo04's Avatar
are you running an MSD box or anything?
Old May 3, 2010 | 05:04 PM
jsetzer's Avatar
When you have trouble like this on the dyno, ask them for a graph with no smoothing. It is helpful to see what it is doing, but sae 5 will even out some of it.
Pretty much already been said but, either valve float, or ignition. When I had plug gaps too bit or not enough spark it would flat out misfire and buck/spit. You could see spikes up and down in the graph. Yours looks like it just hits a wall. What springs are on there? Remember you need more spring than normal because of boost.
Old May 3, 2010 | 07:29 PM
slowZ's Avatar
No i am not, i had one but sold it with my supercharger setup because it had the btm built in and didn't need it after i got tuned. but i am getting another one in the next couple of weeks hopefully.
Old May 3, 2010 | 07:33 PM
slowZ's Avatar
Yeah the un-smoothed one looks like hell, i can get one from them if need be but its just like this one, just more jagged. i have the Patriot Golds (135 closed/375 open) and on advice form bret i am shimming them to 1.7 and seeing what happens
Ericksd
Jan 20, 2016 06:07 PM
ZXXVIII
Sep 1, 2015 10:13 PM
Schul365
Aug 22, 2015 10:00 AM
meissen
Aug 11, 2015 06:05 AM
surreybrad
Jul 5, 2015 10:36 PM
