Target "Boosted" Compression
Using this boosted compression calculator ( http://www.rbracing-rsr.com/compression.htm ) my boosted compression is 19.31:1 and without altitude correction its 19.41:1. Is this to high? What is a target compression to aim for when going with FI? I really want the motor to last, so any info is appreciated, thanks.
Re: Target "Boosted" Compression
Originally Posted by PsstTA
Then what is the correct way to figure your boosted compression? Sorry about this, im a noobie to FI
Rich
Use this calculator. Based on DCR and accounting for atmospheric conditions (natural and unnatural
-Mindgame
).-Mindgame
The reason I am doing this is because I am building a FI 383 over the winter. I wanted to drop the compression down to around 8:1 or so and was told that it wasnt needed. I want to run at LEAST 17#s of boost with room to run more if I desired. I was told that 9:1 was plenty low enough for 17 pounds with room to spare. Any inputs on this?
Rich
surreybrad
Sep 29, 2015 09:00 PM
