Speed Density turbo
Speed Density turbo
I was just looking through the august issue of High preformance chevy, pg 135. It looks as if they took a stock tuneport setup, used a holley 950 computer, bigger injectors and a 2 bar map, and they have a working turbo kit.
I have a 93 camaro, and I really want to put a turbo on it. I did some research on the topic here...and I couldnt find about about 93s. What is the easiest way to turbo this car?
Check out www.speeddensity.org There is a ton on knowledgeable guys on there that can help ya out.
Easiest way to do the 93 would be to just use the stock computer for the gauges and speedo, and add an aftermarket ECU to run the motor. Tuning the stock computer with a chip would be a pain for a 2-bar input, if it can be done.. IMHO!
Re: Speed Density turbo
Rooster,
Could you tell me how you did this. Im a mechanic....Im doing everything myself except the computer programming.... Any info you could give me I would really appreciate.
Jul 4, 2005 05:00 PM
