Spectre air filter warning
Old Jan 8, 2010 | 10:10 AM
cause4panic's Avatar
When i first got my car together I simply ran over to AZ to pick up a cone filter with a 4" inlet.... el cheapo spectre worked great. Tested the car with the filter on and off and found no difference in power, so i said screw it i will run it. I find out now that these cheap filters can implode and destroy a turbocharger. I haven't seen it mentioned here so i figured i would share.
Old Jan 9, 2010 | 08:11 AM
NJ-LE's Avatar
cause4panic:
Thanks for the warning. It appears to be an inverted cone (double cone?) filter. I'm guessing the inner cone rips off or the outer begins collapsing and allows the inner cone to contact the impeller. There are 4" x 9" single cone filters, I suppose they wouldn't be able to collapse enough to enter the machinery.
Old Jan 9, 2010 | 09:36 PM
paxtonLT1's Avatar
love the car.
Old Jan 18, 2010 | 09:53 AM
CALL911's Avatar
That could turn very ugly if not noted. Thanks!
PCLZ28
Dec 24, 2015 05:19 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Latronaxe
Apr 29, 2015 08:25 AM
kksi
Mar 21, 2015 09:03 PM
Jazsun
Dec 29, 2014 12:14 PM
