some problems after SC install
Old May 20, 2006 | 06:51 AM
  #16
30thTA0525's Avatar
Re: some problems after SC install
no mine is a blow off valve.. it has a 2 bolt flange that has been welded into the up pipe from the blower.. i think its a stocker off of a DSM and its functioning correctly.. air comming out at idle or anytime there is vacume.. sounding off anytime i let out of it (when hose was off) i know the vacume source is good and im 99% sure the FMU is good im hoping its the filter if not that then its somthing with the intank pump i think
Old May 20, 2006 | 12:16 PM
  #17
Flip94ta's Avatar
Do you have a inline booster pump or upgraded intake pump? If you have neither than thats you problem. There NO way a factory fuel pump will feed boost.
Also since you have a BOV than is it after or before your maf, if the BOV is after your maf The engine is not receiving as much air as it thinks and is way rich.
Old May 20, 2006 | 02:47 PM
  #18
30thTA0525's Avatar
the BOV system works perfect and as stated ive got one of the MSD booster pumps i think the filter is clogged or there is some sort of obstruction in the trank thats plugging things alot the way.. i push in the stradder valve last night after sitting and nothing.. turn the key and let the pump run then turned it off and very very little pressure was in there just a small amount of fuel came out
Old May 21, 2006 | 05:37 AM
  #19
pavement pounder's Avatar
Could this work wel to keep the crankcase under vacuum and trap oil at the same time ?
Old May 21, 2006 | 05:42 AM
  #20
Old May 21, 2006 | 05:45 AM
  #21
http://motors.search.ebay.com/oil-ca...Z6028QQsaspiZ2
It's kind a cheap on Ebay
97Z28Muscle
Feb 6, 2015 10:44 PM
97SSdude
Dec 31, 2014 07:43 PM
Red97LT1
Sep 7, 2002 09:29 PM
yosshimura
Aug 12, 2002 06:47 AM
Chrisdude
Jul 24, 2002 02:25 PM
