So... Compression.. Dished Pistons
Old Feb 13, 2008 | 01:59 PM
  #16
Tricked-Out-Toy's Avatar
Running them to destruction is fine an all until in the process you take out something else like the block, heads, intake, tranny. If your a manual transmission and the engine locks up at highway speed itll send you off the road in a hurry..... those are just a few of the problems I was thinking about when I was tossing around the idea of just doing a cheap setup till it blows.....
Old Feb 13, 2008 | 03:13 PM
  #17
GMRL's Avatar
Well, if your set on doing that check this out.
http://store.summitracing.com/partde...8&autoview=sku
these pistons, -22CC dish is the most I could find.
Make sure you get correct rings that wont butt together since those ringlands will be weak under all that pressure.
with this gasket, i dunno if you can use it or not, it has a big bore is made of copper, no experience with any of that. Would get you right around 9.1:1
http://store.summitracing.com/partde...5&autoview=sku
This one would maybe work better I dunno, looks like a standard gasket. Would get you around 9.2:1
Old Feb 13, 2008 | 06:00 PM
  #18
LT1-TA's Avatar
Well sounds like .060 over wouldn't be the best idea on a high boost motor anyways. Heads... hmmm.. heads. I need to get aftermarket heads so I can get a bigger combustion chamber. If it took em out it would just forced me into some heads right away.
Its an auto.
But yeah I hear ya. Im gunna beat the stock motor for a bit while getting a 2 bar system figured on the LT1 pcm. Maybe throw some pistons and beat it with as much as the 42# injectors will keep up with (and get a meth kit on it). Then winter rolls around I want to do the engine right and with a new fuel system.
Yeah but... for the price of those i could get the forged ones that 1982z28with18s suggested
Old Feb 21, 2008 | 10:50 AM
  #19
mzgp5x's Avatar
I did a 6" Eagle H_beam with a Calies Dragonslayer 3.75" stroke. Used JE -28cc blower pistons (4.030" bore) with AFR 54cc chamber vol. heads and deck heigth @ 0.010". A Felpro 1074 head gasket would result in 9.5:1 static compression. That's where I am today with a LT1 383 - D1 intercooled/ meth_inj, and a 7.6 --> 3.4" drive pulley ratio. Also did 4-bolt main cap mod. Hope this helps. B.
Old Feb 21, 2008 | 12:02 PM
  #20
jrutland's Avatar
These are the ones I have in my motor.
Old Feb 21, 2008 | 06:38 PM
  #21
LT1-TA's Avatar
Not available in my .040 over bore
Old Feb 21, 2008 | 06:53 PM
  #22
jrutland's Avatar
Dang.
Old Apr 12, 2008 | 11:11 AM
  #23
c0rey's Avatar
Originally Posted by 1982z28with18s
http://www.cnc-motorsports.com/produ...ID=7410&CtgID=
That won't get you as low as you want, but WAY BETTER than those junk HYPER pistons.
What would they give for compression on stock heads?
Old Apr 12, 2008 | 05:41 PM
  #24
GMRL's Avatar
4.04" Bore
3.48" Stroke
4.125" Gasket diameter(felpro 1074)
.039 Compressed Gasket thickness(felpro 1074)
54cc Stock chamber volume
-20.3 Piston dome volume
.015 deck height(average number)
That brings us to 9.50:1.
That number should be pretty accurate.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
