single or twin
Old Oct 29, 2003 | 07:33 AM
masterpower's Avatar
single or twin
going to turbo charge a small block and want to know if to use two turbos or one,someone said two T70 would do better than one big one.Any comments
Old Oct 29, 2003 | 07:47 AM
sleepybu's Avatar
2 t70s would put you in the 8s ez(with a good tune) You can get a single turbo that'll put you in the low 7s hi 6s...
how fast you wana go?
Old Oct 29, 2003 | 10:34 PM
ok this is what i have
Accel dfi,T70 -two of them,brodix pro1 heads,carillo rods,scat crank,JE pistons. and world products small block. Waiting on exhaust manifolds but like i said every one tells me to get rid of the two T70 and get a huge single.What size single should i get and with what size back end.
Old Oct 29, 2003 | 10:39 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
if the class you race in allows twins, I would probably go that route.
Old Oct 30, 2003 | 05:35 AM
really want to know
all i really want to know if i can get lower ets running a huge single as compared to two turbos,looking to make close to 1500 hp with a small block.Where i live we dont have rules or class restrictions,just run what you bring.I want to run sixes in the quarter.
Old Oct 30, 2003 | 08:39 AM
mongse_1's Avatar
Start looking at some 101 or 106mm if you go singles. Also take a look at the times the Blue Oval guys are running w/ Cartek's Dominator kit.
http://www.cartech.net/fordturbofox.htm
Old Oct 30, 2003 | 05:57 PM
96speed's Avatar
Re: really want to know
Find a different message board. I think you are starting at the wrong place .
Good luck!
Ryan
Old Nov 2, 2003 | 05:19 PM
zturbo's Avatar
For your hp wants (1500 hp) I would stick with the t-70's or step back to a set of t-66's or t-68's. Reasoning on not using the big single is to spool it up. A 101-106 mm turbo is going to produce well over what you are wanting (1500) I have a set of 66's that i had on my car and was going for about what you are but with a few changes i went with a single big turbo to go all out. (t-100)
Basically you can accomplish what you are after either way. I have seen twin t-70's make 1670 hp running a air-air inetercooler setup.
Imo its going to be all in the tune and how you set it all up. I choose to use a lil less boost and run more compression in the motor.
Who did your headers?
Steven
Old Nov 4, 2003 | 03:50 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
If your going to run a 106mm, just make sure your motor is over 400cid. spool up time takes days with anything less.
Old Nov 4, 2003 | 06:54 PM
sleepybu's Avatar
Steven
was that in a white regal with a sbc
Old Nov 4, 2003 | 09:32 PM
zturbo's Avatar
No a mustang with a 306 ci setup.
Have seen turbo's in the t-70 series in twins on a black gn (not chow's car) as well as some others, but the one I am refering to is a mustang.
Steven
brothaslide
Jan 9, 2016 12:11 PM
RX Speed Works
Oct 1, 2015 10:19 PM
cmsmith
Sep 14, 2015 09:25 PM
Slayer
Aug 17, 2015 03:55 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
