Ross Blower Piston
Old May 2, 2008 | 04:53 PM
c0rey's Avatar
Ross Blower Piston
Checking out rosses website and found this piston. I talked to the guy at ross and he said it isnt dished its a flat top but its 130 thousands in the hole. Im a newb to firguring calculations and all that stuff. Do you all think this piston would be a good choice with lt1 stock heads?
http://www.rosspistons.com/auto_stoc...?cat=1&item=22
Old May 2, 2008 | 09:48 PM
engineermike's Avatar
Alot of folks will say that the lack of quench is going to kill the power. However, just keep in mind that the SRT-4 runs the piston .340" in the hole at TDC and they do pretty good.
Mike
Old May 2, 2008 | 11:13 PM
c0rey's Avatar
Im really considering giving it a try, they are priced very reasonably as well.
Anybody wanna do a compression calc using stock heads untouched, with .039 headgaskets, stock stock and 5.7 rods?
Old May 3, 2008 | 06:58 AM
rskrause's Avatar
Moderator
Ross has recommended this for years. They are company that has been around for years and makes a good product. I am not saying this method of lowering compression will not work, as I suspect "quench" doesn't mean very much in a blower car due to the turbulence of the mixture. However, they are the outlier and none of the other well known piston manfacturers does it this way. I'd be a little reluctant.
Rich
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
