prochareger
Old Jan 31, 2007 | 08:50 PM
  #16
rskrause's Avatar
Moderator
Originally Posted by markinkc69z
I suppose a guy with only numbers as a screenname might not have a big sense of humor. Sorry for that.
Old Jan 31, 2007 | 08:58 PM
  #17
12345678910's Avatar
my bad didnt mean anything by it
Old Feb 1, 2007 | 08:11 AM
  #18
CALL911's Avatar
IMO, its not cost effective to spend the $ on s supercharger, and then only be able to run under 7#'s of boost safely. Unless you simply want the satisfaction of knowing your car is supercharged.
If you want more bang for your buck (cheep wise) go with a nice set of heads and a bigger cam.
If you really want to make potential from a supercharger, save the $, and get your car setup to take the boost that a REAL supercharger would put out like a D1 unit or Vortec-T trim equivilant.
Old Feb 1, 2007 | 10:08 AM
  #19
mzgp5x's Avatar
I had a p600b once. Did all the pulley mods I could. It ran out of potental, and, I got a D1. Now I wish I would have bought the F1.
Old Feb 1, 2007 | 10:50 AM
  #20
CALL911's Avatar
Funny how often this story is told.
Old Feb 2, 2007 | 02:22 AM
  #21
30thTA0525's Avatar
if your car has TCS it will get in the way.. you will have too relocate some of the ABS parts that the 4 channel ABS system contains
Old Feb 2, 2007 | 05:17 AM
  #22
would that be in the instructions the kit would come with
Old Feb 2, 2007 | 06:33 AM
  #23
joe-96z1le's Avatar
Kit comes with brackets to relocate the ABS module.
Old Feb 2, 2007 | 04:01 PM
  #24
thanks
Old Feb 4, 2007 | 05:15 PM
  #25
so 8psi intercooled would be safe for a while right going to get a tune and upgraded fuel system along with it
Old Feb 4, 2007 | 09:46 PM
  #26
CALL911's Avatar
You should be alright, although 6 psi would be safer. Let me know if you want a cheep fuel upgrader. I have a brand new ATI booster pump I'll let you have for cheep.
Old Feb 4, 2007 | 10:11 PM
  #27
anyone alse run 8psi intercooled on stock engine for a while without problems
Old Feb 5, 2007 | 06:18 AM
  #28
CALL911's Avatar
If it makes any difference I saw my old boss run 8-9#'s from a D1 unit on his stock bottom end LS1 WS6 (twin intercooled). He lasted a whopping 2500 miles before he fried a piston.
Old Feb 5, 2007 | 03:58 PM
  #29
looks like i might end up doing heads and cam then
Old Feb 5, 2007 | 04:22 PM
  #30
CALL911's Avatar
Keep in mind that he had a "mail order" tune, and not a dyno tune done on it. There are other guys who have ran 6-8#'s on the stock bottom end and lasted quite a while.
IMO, when it comes down to it, its not cost effective to spend that much money on the blower, and not be able to run enough boost to get you much power. If cost is what is holding you back from building the motor to take more boost, I would agree with your call to go with a good heads and cam combo instead.
