prochareger
Old Jan 30, 2007 | 09:45 PM
12345678910's Avatar
prochareger
i was thinking of getting a p600 procharger kit for my car and was wondering what the results would be. thanks
Old Jan 30, 2007 | 10:03 PM
reamo04's Avatar
check the forced induction section
If you can afford it, look at the p1sc and d1sc
Old Jan 30, 2007 | 10:56 PM
lethal93ta's Avatar
my car was basicly stock, just some bolt ons, I was running 13.8-13.7 @ 101-102 MPH, I put the P600 on mine ran the 9 lb pully and I ran a 12.26@115 MPH, a 1.5 second loss and 13 MPH gain, I was impressed, if I would have got a chance to get a converter and gears in my car I know it would have went into the 11s easy.
Old Jan 30, 2007 | 11:33 PM
Kraest's Avatar
Retired
I wouldn't play around with a p600 if you paid me.
The smallest one I'd get is a P1SC, then a D1SC, then a F1.
That's pretty much how they progress.
Old Jan 30, 2007 | 11:39 PM
what do they run stock boost wise. and what was your 60 when you ran that thanks
Old Jan 31, 2007 | 04:25 AM
lethal93ta's Avatar
I was only getting 1.9 60 foot times, I needed gears and a stall to get it off the line harder.
Old Jan 31, 2007 | 06:16 AM
does anyone know is this will work with traction control
Old Jan 31, 2007 | 08:43 AM
97WS6SCharged's Avatar
Most kits will work with the TCS, however with Vortech's aftercooler you would need to relocate the module.
LT1s are limited to around 8-9 PSI intercooled, 5-6 non-intercooled.
Old Jan 31, 2007 | 11:51 AM
slimdawson's Avatar
Lol.
I'd turn it off and take control of what you want to happen.
I have a p600b that I have been happy with for as long as I've had it. I've only had one belt since I started running it. I'm running ~8lbs and went from 295 rwhp to 456 rwhp. Although I could have went faster on nitrous, I love my Procharger.
Old Jan 31, 2007 | 03:28 PM
how many miles do you have on it i want to run 8psi but my car has 95000 on it so i was thinking only 6psi could i get close to 400rwhp with only 6 psi. thanks
Old Jan 31, 2007 | 03:30 PM
the kit is also intercooled
Old Jan 31, 2007 | 07:24 PM
slimdawson's Avatar
Couldn't tell you exactly. Probably around 90k or so. Had the charger on for about 3 years now.
Old Jan 31, 2007 | 07:46 PM
markinkc69z's Avatar
It will make your traction control feel inadequate and ineffectual. If you respect your traction control's feelings you should remove it.
FWIW the P600B and P1SC share the same impeller design and both are capable of 1200 cfm. The P1SC is easier to drive to high airflows due to its 4.10 internal gear vs. the 3.05 of the P600B. Both have the same overall performance potential.
Old Jan 31, 2007 | 07:55 PM
i can turn it off so why take it off just wanted to make sure it fit
Old Jan 31, 2007 | 07:58 PM
I suppose a guy with only numbers as a screenname might not have a big sense of humor. Sorry for that.
