prochareger
Old Feb 6, 2007 | 10:55 AM
  #31
12345678910's Avatar
anyone else survivse 8psi stock for a while
Old Feb 6, 2007 | 04:28 PM
  #32
lethal93ta's Avatar
mine ran for over 2 years with 9 lbs intercooled, and that 2 years was probably the 2 hardest years in its life, it was always hammer down, but mine only had 60000 miles on it when i put it on there.
Old Feb 6, 2007 | 04:34 PM
  #33
Kredz28's Avatar
Cylinder 5 showed 50% on a leak down test (not good). You can make it last for a while, but you need to get it on the dyno and make sure your running on the richer side. You should also add colder plugs (i run the ngk tr-6). If you get the air/ fuel ratio to around 11.5:1, you should be ok...just try not to beat the **** out of it every stoplight and itll be OK for a little while...There are guys out there running on the stock bottom end, but its really hard to say how long it will last..
Old Feb 6, 2007 | 04:56 PM
  #34
joe-96z1le's Avatar
I ran 8psi, 3 row ProCharger IC, 24 lb SVO inj, FMU, in-line pump, stock timing, no dyno tune for quite a while with no problems. I never opened up the needle valve on the FMU to make sure it always ran rich. But for the good luck I had there's plenty of others who broke pistons within a couple thousand miles or less. Luck of the draw, I guess. But eventually, I did crack some ring lands. I bet if a few degrees of timing were pulled on the top end it would of lasted longer.
Old Feb 6, 2007 | 05:26 PM
  #35
how many miles is a long while joe thanks
Old Feb 6, 2007 | 06:40 PM
  #36
joe-96z1le's Avatar
Kinda hard to say exactly but about 15-18,000 miles. I changed my setup later so that I went with a dyno tune, ported heads, delete FMU, bigger inj. My boost dropped by 2 lbs. but HP went up. BTW, keeping tabs on fuel press. is pretty important. You should install a fuel press. guage also.
Old Feb 6, 2007 | 09:23 PM
  #37
anyone know what pullies to run to get 6psi of boost for a p600b
Old Feb 8, 2007 | 08:28 PM
  #38
any other lt1s survive boost for a while need to know and thanks to all who replied
Old Feb 9, 2007 | 06:37 AM
  #39
CALL911's Avatar
IMO, 6-8#'s intercooled you will probably be alright for a while. But even if you play it safe, it is still risky on how long you will last, and the odds are that at best you might survive 25,000 miles or less.
If you only run 4#'s, you'll probably last twice as long, however at that point it goes back to what I originally was saying about not being cost effective (thousands of dollars, with minimal HP increase)
If you think eventually the motor is going to be rebuilt anyway, just put the small blower on, and let the good times roll. Then when it blows, do the rebuild to handle boost, and then you can go with a smaller blower pulley and have some REAL fun.
When it comes down to it, you need to ask yourself if you would be happier with a blower car for a short amount of time? Or would you rather save the $ needed to build a motor to handle boost for a long time? You can always spend (probably less) $ elsewhere and go with a good head and cam combo that will make more power than a blower would at only 6-8#'s anyway.
Old Feb 9, 2007 | 04:14 PM
  #40
well decided its time to save some money and do it right and get a built motor then run with a procharger thanks
Old Feb 9, 2007 | 04:30 PM
  #41
CALL911's Avatar
I'd say you made an excellent choice!
