problem after fmic
Old Jul 16, 2006 | 01:01 PM
blownbird01's Avatar
problem after fmic
I just did a front mount intercooler on my 95 firebird. I fired the car up and its loading up with fuel. The car is blowing a little smoke and running rough. You can smell the fuel in the exhaust. My mods are in my sig. The car ran perfect before. It is an obd1 car. I had the battery disconnected. The car normally runs crappy when the battery is off. Its never ran like this before though. Any ideas?
Old Jul 16, 2006 | 01:26 PM
Sparkz28ss's Avatar
Re: problem after fmic
is the maf hooked up?
is the maf in backwards?
is the maf clean?
is the IAT hooked up?
do you have a boost leak after the maf?
Old Jul 16, 2006 | 03:01 PM
I cant tell if I have a boost leak. When I give it throttle, my boost guage is reading the right amount of boost. I didnt check to see if the maf is dirty. The maf is hooked up and so is the iat. The maf is not in backwards. It is acting like a maf problem though.
Old Jul 16, 2006 | 05:43 PM
I also pulled out my cruise control box and my windshield washer resivoir. I have a th350 trans so the cruise does'nt work anyway. I dont think disconnecting the cruise wiring would hurt anything. I tried plugging it back in but it still does it.
Old Jul 16, 2006 | 07:50 PM
Sean94Z's Avatar
Disconnect the MAF and see if the car runs right.. If it does, then you have a vacuum leak somewhere after the MAF.
Old Jul 16, 2006 | 09:08 PM
97WS6Pilot's Avatar
Can you post pictures of the front of your TA?
Old Jul 17, 2006 | 12:07 PM
mongse_1's Avatar
You took my answer!
I have a couple on my site.
http://www.quarter-mile.net/blackta/...ior/?g2_page=2
Don't have anything recent, just the ones with the bumper in red.
Old Jul 17, 2006 | 02:56 PM
CALL911's Avatar
I don't think your problem has to do with your FMIC. Keep looking elsewhere IMO like suggested above.
Old Jul 17, 2006 | 08:35 PM
I swithched out the maf sensor, still does it. I tested the wiring from the maf, its fine. I changed out all my plugs, still doing it. I scanned the computer and did not find any codes. I unplugged my o2 sensors and it did not change. I checked the iat sensor and it was good. I tested the map sensor and thought I found the problem. At idle, the map is supposed to be putting out 1.2-1.6 volt. Mine is putting out 2.6v. When you rev the car, the volts are supposed to go up. Mine actually went down to 1.9v. Now I dont know how its suppose to act with a blower. I changed the map out with one off a friends car and the car was still doing the same thing. I'm pretty much at a loss. Anymore help would be greatly appreciated. The car starts fine but the idle is choppy. Then as I'm reving it, it is stumbling the whole way through the rpm range, but it does run. ????????? Its loading up with fuel pretty bad.
Old Jul 17, 2006 | 09:35 PM
JZ28Max's Avatar
i had my bypass mounted too close to the maf and it ran rough. i believe it will cause some bad maf readings because of the turbulent air. just something you may want to check. also your cruise should still work. mine did with the t400.
Old Jul 18, 2006 | 05:12 PM
The blow off mounted too close to the maf should only cause a problem at idle. When you give it gas, the vaccum turns to boost and closes the valve. My car is having problems from idle up. Any other thoughts, anyone?
Old Jul 18, 2006 | 05:51 PM
SC/TA's Avatar
Make sure the temp sensor on the water pump is connected good. That will make them run rich.
Old Jul 18, 2006 | 05:52 PM
Bryan 94 Z28's Avatar
Not necessarily. I can drive around town all day without getting into the boost. The entire time the bypass/blowoff would be open due to the vacuum, causing turbulence. I dealt with this problem as well.
Old Jul 18, 2006 | 06:04 PM
Ok, I see what you are saying. I was just saying that when I get in boost, it's still doing the same thing. I also tested fuel pressure. At idle its 40psi, not much change when reving car. My vaccum is 13hg at idle. Both seem to be ok. I'm wandering if this is an ignition problem. Every single spark plug was black and they all looked identicle. My plugs are always clean. I have a accel ignition and it went bad once already. The car wouldnt start then though. Maybe a bad coil?
Old Jul 19, 2006 | 08:28 PM
OK, I just unplugged the maf harness and the car runs fine. Do you guys think there is a leak in the blower plumbing? I dont have time tonight to pull the front end back off. Just wandering what you guys think.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
