Poor boys buildup
Old Feb 26, 2004 | 09:26 PM
  #16
SMOKNZ's Avatar
Originally posted by jsetzer
Lots of help on this forum..... How many users are here again?
Oh and this surely isn't a good way to get help either
Old Feb 26, 2004 | 10:57 PM
  #17
97WS6SCharged's Avatar
I may be wrong here, but I think the reason you aren't supposed to mount a turbo at an angle has to do with the way the oil drains from the turbo. If you mount the turbo at an angle, the oil drain wouldn't be at the bottom of the turbo so oil would build up inside and play havoc with the seals and whatnot.
School me if I'm wrong here.
Old Feb 26, 2004 | 11:23 PM
  #18
jsetzer's Avatar
Thanks again guys,, keep it coming for me...... really didnt want to do a header,, but if its a must.... could do abs delete,, then put it up there..... just got to keep thinking
Old Feb 27, 2004 | 07:22 AM
  #19
Geoff Chadwick's Avatar
I *think* Jordan Musser did an ABS Relocate job... Dont know if anyone else ever did - but aside from the visual satisfaction of a more open engine bay - it'd physically open up a lot more room. I wonder about that one myself.
Old Feb 27, 2004 | 04:02 PM
  #20
96TurboTA's Avatar
Doesn't the ABS system have to be bled by a professional once you unhook it from lines? I'd love to relocate my ABS module.
Old Feb 27, 2004 | 05:54 PM
  #21
v7guy's Avatar
if I remember right the system onl;y has to be bled if the ABS was activated the las titme before it was disconnected or if the system was activated while you had a leak otherwise the valves stay closed and you can bleed it normal per instructions
Old Mar 5, 2004 | 02:34 AM
  #22
Secret Formula's Avatar
Appreciate it, my main worry was that I had been told prev that t3 would not support the boost i wanted..
Sort of right. Boost is just air pressure, you can blow air into a straw with your mouth and make 6psi, but it won't feed your hungry 350. T3s are capable of 20 to 30 psi...
But you need airflow as well, and a T3 won't supply enough air. Two of them would. Probably around 40 lbs/min, or 600cfm is what you would need.
Who makes a 3-4ish psi wastegate? keep finding the 5.xx ones a lot,, not any smaller though....
Tial does. Mine is a Tial 38mm and has a 4psi spring (0.3 bar). $220
KYWes
Sep 26, 2015 08:49 AM
NewsBot
Sep 15, 2015 11:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
Boss002
Jul 24, 2015 10:47 AM
C4m4roJoe
Jul 19, 2015 10:59 PM
