a pic of my twin turbo setup
Old Apr 27, 2004 | 10:58 PM
  #16
got_hp?'s Avatar
Originally posted by LT1RX7
They are twin TO4B turbos, twin 35mm Tial wastegates, custom FMIC, Apexi BOV, stock bottom end, mild port heads, cam
all that work and just a stock bottom?
do you plan to upgrade later, cause im sure those turbo's will put out plenty more than the stock bottom can handle.
Old Apr 28, 2004 | 01:31 AM
  #17
texlurch's Avatar
Looking good! Always nice to see another home built turbo LT1..
You got those valve covers from Summit? I still haven't decided what I want to get, kinda like the polished GM ones..
You'll like it when it gets going! Even with the stock bottom end.
What kind of PCM and controls did you go with?
Old Apr 28, 2004 | 02:34 AM
  #18
neil350's Avatar
Good gawd all mighty, my jaw dropped when I saw that.
Old Apr 28, 2004 | 06:32 AM
  #19
lt1camaroman93's Avatar
what gear drive did you use? I was going to put one in my car when i had it torn down, but didn't know which one would fit under the cover.
Old Apr 28, 2004 | 05:53 PM
  #20
SMOKNZ's Avatar
I second that question
Pete Jackson
http://www.jegs.com//cgi-bin/ncommer...79&prmenbr=361
makes a gear drive for SBC Hydraulic roller cams (87+) with the exception of the LT1, but as long as you ditch the water pump drive it would probably fit. I think I'll try it
Bill
Old Apr 29, 2004 | 12:44 AM
  #21
LT1RX7's Avatar
Originally posted by Jesse_Boyer
I spend hours on these boards and i'm NEVER bored. We're gonna need all the details you can fit in a 50 page Word Doc... GO!!
Well, maybe it'll just make me bored than
John, The intercooler will work perfect. I changed how I'm going to route the piping but everything will work out fine. I'll be making my crash support this weekend hopefully
Crash support? Who needs that Good to hear it worked out for you. I'll be having mine made next week with the same size core, just side to side
I'm sure I'll toast this motor within a month of boosting on it so I know what's coming. I'll end up stroking it out, probably to 383 but it's still up in the air right now. I really want to see how much the stock bottom end will handle
Old Apr 29, 2004 | 12:51 AM
  #22
LT1RX7's Avatar
I got these covers from Jimlab but I'm sure the ones that summit sells are just as good. Polished GM covers are nice, very nice. I just like the look of fabrication
I have just a stock PCM with an LT1 edit. I'm still playing around with the idea of mounting one MAF sensor to only one side of my intake. This should only read half of the air I'm actually taking in. I've read that the MAF can only read up to 500hp. My way should be good enough for close to 1000hp, I hope
They are the ones that Smoknz has the link of. The only reason they exclude from LT1 models is because we have a knock sensor that will trip out with the gear drive kit.
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Fastbird93
Apr 9, 2016 07:01 PM
LT1runner
33
Jul 24, 2002 01:19 PM
