P600B idler pulley bearing replacement
Anybody have the part number for the bearings in the idler pulley on the P600B LT1 kit. It is for the 12 rib pulley. They have a little squeak right now so id like to get on it before its a problem. Im not getting any deflection of the main bracket and my pulleys are lined up perfect...........it just sounds like a high pitched squeak at idle. No belt throwing or chewing, just squeak. Thanks Eric L
I had evidence of bearing races spinning in the pulley cause they fall right into place when the grease is cleaned off so I loctited them in there.. probably didnt do a damn thing to help that crap design.
I called procharger today and they said they didnt know the part number, and that all they could sell me was the whole assembly. And fwiw, I put a new bearing in my tensioner pulley (the LT1 factory one, not the procharger one) and I found it helped to knurl the pulley before pressing in the bearing, gave it a little more bite. I just used an all and some 40 grit paper. Thanks Eric L
stockssn2o
May 25, 2015 08:54 AM
1LEThumper
Jul 14, 2003 12:45 PM
