Need Lower compression without changing bottom end...ideas?
Old Dec 4, 2009 | 02:58 PM
Jameslt1TA's Avatar
Well i built my motor for nitrous but i would like to go with forced induction if i could. Pretty inrestead in the Lt1 boost shop car turbo kit.
Alittle backround on my motor. 355ci 4 bolt splayed billet main caps, stock lt1 crank(turned), scat forged i beams, And mahle pistons. The problem is the compression ratio is about 11.5 to 1 and i want about 9.5. I have advanced induction heads with probably 64cc chambers, could i just port these out? Does afr make some 76 cc heads, will this drop the comp enough? could i run a thicker head gasket? Clint(lt1T/A on here) built the bottom end to hold a 250 shot of nitrous so i think it could haddle 12-15 psi with no problem.
Thanks guys
James
Old Dec 4, 2009 | 10:02 PM
blown94's Avatar
I think you'll have a hard time getting to 9.5:1 from 11.5 unless you go to 76cc heads with chamber work. Also, what scat I beams you got? They make a couple. If you didnt get the 7/16 8740 bolt rods minimally you might want to re-think the bottom end for boost. The lesser rods are only rated to 500 hp I believe, and thats just asking for disaster with boost.
Old Dec 5, 2009 | 12:00 AM
MikeGyver's Avatar
lol use like twelve head gaskets.
Old Dec 5, 2009 | 06:45 PM
Jameslt1TA's Avatar
I dont remember which rods i have...its been like 4 years since ive even messed with this motor. Maybe ill just run nitrous.
Old Dec 6, 2009 | 12:05 AM
z28_4life's Avatar
Gotta love upgrading to bigger heads!
Old Dec 7, 2009 | 09:48 PM
Jameslt1TA's Avatar
Originally Posted by Z28Roxy
Custom headgaskets and very large chamber AFRs might get you there, IDK. And why did AI make your stock heads 64cc? Normally they make the CC smaller.
Im not sure the actuall cc of the heads as i bought them used and have am just getting back into the lt1...lol ive forgot alot about it.
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
HectorM52
Jan 31, 2015 07:29 PM
Jan 23, 2015 01:13 PM
Killer94z
Jan 13, 2015 12:06 PM
