Need Help placing oil and trans cooler on supercharged lt1
I got a 95 camaro with a vortech v1 si trim on it.Where is evryone else putting there oil coolers or trans coolers?I Need my car to run alot cooler then it is.Any tips on making it run cooler will help thanks.Already got a 160 thermastate and my water pump works fine and i changed the radiator and fans.Please help me out!
I put my trans cooler in front of my radiator onto the condensor. It helped a lot! I want to say it dropped the trans temp about 20 degrees in the summer. It's been awhile, so I can't fully remember.
http://i85.photobucket.com/albums/k4...charger019.jpg
http://i85.photobucket.com/albums/k4...charger018.jpg
Do you have an electric water pump? I've heard that if you do, you should remove the thermostat as it cools better that way. I haven't checked that info out yet, and was going to look into that before I put my motor back together. Maybe someone here has some knowledge regarding that?
