need help with single turbo LT1
Old Jun 22, 2007 | 01:47 PM
  #16
RealQuick's Avatar
Originally Posted by reamo04
thanks for your help realquick, what do u think i could hit horsepower wise with the t-76 on a 383 (if built correctly) thru an AT?
Engineermike is at 700rwhp with his log manifold setup and a T76GTS (the best T4 T76 out there)... so he is at the upper limit. I'd say realistically... 600-625rwhp is a good number to shoot for if you have a good set of ported heads and a decent cam.
Jon
Old Jun 22, 2007 | 01:48 PM
  #17
reamo04's Avatar
Jon
alright, do u think LE3s would be fine, or ported trickflows, or maybe pick up some of the new brodix heads, or what?
Old Jun 22, 2007 | 01:51 PM
  #18
RealQuick's Avatar
In order to lower the compression, pick up some deck height and get the most flow... the LE ported TFS heads would be great. LE3 heads are great too... but the have the small combustion chambers.
Old Jun 22, 2007 | 02:29 PM
  #19
engineermike's Avatar
Thanks for the prop's, guys.
The T76GTS is a good choice, but there are some alternatives out there now.
If you want to spend a little more money and have a little more room, the new ST series turbo's are awesome. Smaller than the S400, but will support up to 1300 hp. They're a little more pricey, though.
If you want cheaper, the Turbonetics TC76MPS will support 1000 hp and only cost around $1100.
Mike
Old Jun 22, 2007 | 02:42 PM
  #20
reamo04's Avatar
Mike
where do i find one of the ST series at?
Old Jun 22, 2007 | 03:48 PM
  #21
www.forcedinductions.com
It's under Borg Warner.
Mike
Old Jun 22, 2007 | 03:55 PM
  #22
RealQuick's Avatar
Mike
Those Borg Warner ST's are comparable to the T4 GT42's... still freakin huge turbos.
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
blac94Z
Jan 22, 2015 11:19 PM
LT1runner
33
Jul 24, 2002 01:19 PM
