Need help putting together a shortblock for boost...
Old Sep 13, 2007 | 02:55 PM
texasTA's Avatar
I haven't decided yet whether to go 355 or 383, but I need some help on other aspects of the build.
I plan on running around 15-18 #s of boost from a procharger, possibly D1 but not sure yet. Anyways, what length rod do I need to shoot for, 5.7, 5.85 or 6 inch?
Also, what is an ideal piston for such a setup?
Basically if you guys were building a high boost supercharged engine, how would you build it and with what parts? Obviously I am not going to say "money isn't a problem", but at the same time I definately don't want to skimp on the shortblock.
Old Sep 13, 2007 | 03:20 PM
RealQuick's Avatar
The general consensus is that a shorter rod may hold up better than the longer one, so I would choose the 5.7".
I would go with the minimal dish piston / maximum combustion chamber to reach your desired CR. This means if you could pair up a 64cc head/-31cc piston or a 74cc head/-21cc piston I would go with the latter. The piston should be stronger since its thicker.
I am sure other will have their opinions as well. Oh, and I would go with a 383ci.
Old Sep 13, 2007 | 03:39 PM
JustNO's Avatar
Why not going with 64cc head with -21cc pistons ? This will give close 9:1 CR.
Old Sep 13, 2007 | 04:34 PM
crazycat's Avatar
I am looking to do the same thing this winter, a 383 built for boost only it will be a turbo. I would like to know a real good combo, pistons, cam and heads to make 600 to 650 rwhp.
Old Sep 13, 2007 | 09:28 PM
texasTA's Avatar
Okay so let's say a 383
I was thinking :
Callies DragonSlayer Crank
5.7 Lunati Pro Mod Rods
Whatever pistons to make the right CR (What brand do most use with a blower application)
4 bolt splayed billet caps
ARP fasteners all throughout
If I wanted to save some cash on internals, would Eagle parts be okay to go with on the rods and crank?
I already have a good set of LT4 heads. I might get Lloyd to go over them.
Also, what would be a good oil pump and oil pan for this application?
Old Sep 13, 2007 | 10:31 PM
Boosted_Z28's Avatar
There's a reason why a Callies crank is several hundred dollars more than an Eagle crank...you get what you pay for. If you are looking to build a forced induction motor, then you want to buy the BEST parts your wallet can afford. JE has a great choice of blower specific shelf pistons.
A lot of people have had great success with the stock oil pan and pump when running upwards of 600+ hp. I chose to use the Canton oil pan and a Melling extreme duty oil pump.
Old Sep 13, 2007 | 10:45 PM
T/A KID's Avatar
Victory Racing Engines
Talk to Eric he will fix you up
Old Sep 13, 2007 | 11:24 PM
95 Z/28 LT1's Avatar
Super Moderator
I agree, he'll take good care of you and doesn't BS.
Heathen1
Jan 2, 2016 04:27 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Chevyguy358
Jan 28, 2015 08:04 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Queens94z28
Nov 20, 2014 06:03 PM
