motor for boost and N2o
here is what i have for my car so far
Je custom pistons 15cc dish
hellfire rings
Dyer rods (300m)
race master callies crank
splayed 4 bolt main with billet caps
383ci
Trick flow heads
blower cam
cant release specs
chomoly pushrods
titanium retaniers
987 comp springs
FAST computer
72# injectors
full aeromotive fuel system
8an feed
6an return
bmr tank
eliminator pump
D1SC with cog drive
air/water intercooler
hoping for 17-19 psi
NX express N2o kit
going for 650+ on motor blower
800+ on motor ,blower,spray
drive train
street twin
D&D built t-56 (viper conversion)
MMC dynotech driveshaft
moser 12 bolt all options
etc etc etc lol
Steve
what do you think
hellfire rings
Dyer rods (300m)
383ci
Trick flow heads
blower cam
cant release specschomoly pushrods
titanium retaniers
987 comp springs
FAST computer
72# injectors
8an feed
6an return
bmr tank
eliminator pump
D1SC with cog drive
NX express N2o kit
drive train
street twin
etc etc etc lol
Steve
what do you think
Re: motor for boost and N2o
Originally Posted by InsuranceGuy
Nice! Very nice!
Question? Why did you decide to go with the standard
tranny with that killer setup?
Emil:93Z,383,Vortech,NOS,water/methanol,TH-350
it was the stongest manual 6 speed D&D could build for the car
it has everything imaginable done to it for strength
the car is back to stock now i just sold all of the old setup off of it
but here is a pic of the outside of the car
http://www.sicws6.com/images/Dry_Lak...%2005%2069.JPG
http://www.sicws6.com/images/Dry_Lak...%2005%2066.JPG
You will blow it J/K. Give me a call. I will help you get this together. Holly crap Steve by the way when did you start running on FISK.
Nice set up man... now the question is how much $$$$?
Also where are you getting the cog drive for your D1SC? Once again pics of the air/water intercooler would rock!!!!
-B
-B
1. Cog drive = bad idea unless it's a race car only.
2. The injectors may not be big enough.
3. You will need one hell of an exhaust system to avoid choking it off at that end.
4. The CR may be too high to run on pump fuel with that much boost, you should consider water/alcohol injection as an anti-detonation strategy if you are planning on running pump gas.
5. You will need a custom air intake for the SC to see 17-19psi. Even with one, the D1 may not flow enough air to see that kind of boost depending on the rev range you plan to operate in. One of the other problems with a cog is the limited number of belt lengths available will in turn limit the pulley combinations you can use.
6. What are the specs on the "Eliminator" pump? You will need a hell of a lot fuel for this kind of combo.
Rich
Rich
I'm going to be running a 383 with a D1 but without the n2o. I don't expect to see 600rwhp so I was wondering if a single walbro intake fuel pump along with 42lbs injectors would cut it?
-B
-B
-B
-B
Rich
