Making room for turbo... PICS!
Old Jan 15, 2008 | 05:45 PM
  #121
97ChameleonTA's Avatar
Moderator
OK, maybe i'm blind or just plain stupid, but, i've read and reread this thread and I still can't seem to find the part number for the radiator that the OP used. The two part numbers listed in this thread are both 19 inches tall, which is way too tall.
Anybody have an idea???
Old Jan 15, 2008 | 06:26 PM
  #122
lethal93ta's Avatar
GRI-1-25241-X is what I used
Old Jan 16, 2008 | 11:05 AM
  #123
Moderator
Thanks Man! Did you order it as is or did you have them customize it with the inlet/outlet location, etc.?
Old Jan 16, 2008 | 04:48 PM
  #124
lethal93ta's Avatar
I got it right from summit and welded fittings in there for a drain and the return line from the heads.
Old Dec 7, 2008 | 02:41 AM
  #125
ctx97's Avatar
Old thread, but bumping this back up, because I made this mistake of not looking at the size. Two part numbers listed are 19" and way too tall, found this out the hard way.
Old Dec 7, 2008 | 04:35 AM
  #126
reamo04's Avatar
I did this too, what I ended up doing, is cutting out the bottom support as well, and making a new support with 1" square tubing that dropped down and then over. Welded some 1" flat metal bar to it to hold the radiator in place. Worked pretty nice I think
Old Dec 7, 2008 | 08:45 AM
  #127
mzgp5x's Avatar
I had a stock size Be_Cool rad from Summit (for an M6 app 1997). I think larger than the typical popular Grifffin used in these applications. I too cut the bottom rad support (also the top). Fabricated a total new piece (bolt-in) for lower rad support from home-depot steel. I also hang my 25x13x3 IC under there (not in front). It has bolt on bracket features for the IC mount. Since the stock rad is larger in depth (top to bottom), it has a slight angle to it like the stock. I added steel to the lower rad stock frame rail mounts for mounting provisions of the low rad support. Lots of room now with 2 flex-lite low profile fans. Better air flow for cooling. Pics on photobuck. Search under mz... ID.
Old Feb 10, 2009 | 08:02 PM
  #128
ctx97's Avatar
Sounds cool, Can you all post up some pics?
Old Feb 11, 2009 | 03:16 AM
  #129
mzgp5x's Avatar
Photo albums...
http://s306.photobucket.com/albums/nn244/mzgp5x/
Best of luck. B.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
