LTCC timing retard for blower motor
Old Jun 3, 2004 | 04:46 PM
Live for TAs's Avatar
I just bought a used LTCC here, and am looking over the manual. I'd like some input on how much retard the system should be set up with based on my application. Here are the motor specs:
    Retard options are .5 degree per 1,000 RPM up to 3 degrees per 1,000 RPM.
    Thanks for any experience or advice.
    Old Jun 3, 2004 | 05:35 PM
    Highlander's Avatar
    It will depend on your logging and what you have set up in your cal file...
    I wouldn't do less than 2/1krpm just to be safe and START Tuning...
    Old Jun 3, 2004 | 07:55 PM
    Damon's Avatar
    I agree- if you're doing this without a full complement of diagnostic tools- START CONSERVATIVE. Until you get your fuel curve dialed in reasonably close you pretty much rely on the ignition timing to keep you out of detonation. Detonation in a boosted motor is FAR more destructive than in a N/A combo. You can blow the motor in a matter of seconds if you step over the line. And you won't KNOW you stepped over the line until it's too late. Impossible to hear detonation over the exhaust and blower screaming.
    Like Highlander said- THEN START TUNING. Dyno time on something with a wide band O2 would be money well spent BEFORE you start playing on the ragged edge with ignition advance.
    Old Jun 3, 2004 | 08:44 PM
    kmook's Avatar
    Advanced Tech Moderator
    This should be discussed in the Forced Induction forum, transfering.
    HectorM52
    Jul 30, 2017 11:46 AM
    mikey4play
    Mar 15, 2015 11:45 AM
    SpeedJunkee
    Jan 27, 2015 10:02 PM
    1LEThumper
    Jul 14, 2003 12:45 PM
