LS1 Turbo Setup
Old Jan 26, 2009 | 05:39 PM
c0rey's Avatar
LS1 Turbo Setup
Just thought I would share over here with you guys who dont read tech.
I am just starting my truck manifold build
Here is a pic of the old lt1 setup
Here is the same car with the ls1 swapped.
The Run Down
Flipped truck manifolds
Lucas 42lb injectors
MP T70 .96ar
Ebay 38 MM Wastegate 6 PSI Spring
Ebay RFL BOV
Ebay Intercooler
224/224 112LSA
9" with 4.11s
T56
Im not looking for everyones opinions on the ebay parts. Im just showing my build.
Here are some pics from tonight,
I got the injectors swapped,new tune loaded,ac,alt removed. Manifolds mounted. PS lines re routed out of the way.
I ran into a problem on the passenger side tonight.
Hotside is pretty much done. Have to put 02 bungs in and misc little crap like the gate and ect. Here are crappy cell phone pics.
Here is a update. All the piping for the hot side is complete. I got most of the cold side put togther tonight. Things left to do
Install Pillar
Tap Pan
Run Gauges
Alt Relo
Finish Cold side.
Old Jan 27, 2009 | 08:16 AM
RealQuick's Avatar
Looks good!
Old Jan 27, 2009 | 09:10 AM
The SRZ's Avatar
Damn. LS1 envy...almost. What are you using for the ECU, stock, aftermarket? Nice work btw.
Old Jan 27, 2009 | 09:55 AM
Blownbird355's Avatar
Trader What kind of times for the LT1?
Old Jan 27, 2009 | 04:11 PM
c0rey's Avatar
Stock ecu. LS1 pcms are pretty good for tuning 2-3 bar support. I didnt get to run the lt1 to long because I redid the steam line and it didnt it and over pressurized the heads. Live and learn I guess. The ls1 t56 is fun, but the gear ratio isnt gonna like me lol. I have a set of 3.50s to throw back in there that I took out because NA they werent fun.
Old Jan 29, 2009 | 11:06 PM
c0rey's Avatar
Here is a update with some more ****ty camera phone pics. Its all done but cant start it because im waiting on a damn drain line and flange.
Drain and flange will be here 2-2
Old Jan 30, 2009 | 12:05 AM
reamo04's Avatar
man, i knew you would go back to turbo
Old Feb 1, 2009 | 06:09 PM
c0rey's Avatar
Here are some better pics. The car is 99.8% complete. Waiting on the drain flange and line to get here then it will be 100%. Should be able to test drive it tuesday night!
Ground Clearance is awesome
Old Feb 3, 2009 | 05:10 PM
c0rey's Avatar
Its alive!
http://s262.photobucket.com/albums/i...=firstfire.flv
I took it out for a bit last night and it needs some tuning and minor tweaks overrall runs pretty good.
Old Feb 3, 2009 | 11:13 PM
reamo04's Avatar
decently quiet, what exhaust?
Old Feb 3, 2009 | 11:51 PM
ford's Avatar
Dont just tease us with the idle.... I want an in car vid now
Sounds good though.
Old Feb 4, 2009 | 08:18 PM
c0rey's Avatar
Magnaflow with the cutout closed.
It needs some more tuning and ect but ill try to get some videos this weekend if its nice.
DirtyDaveW
Dec 1, 2016 05:37 PM
Fastbird93
Apr 9, 2016 07:01 PM
87Aerocoupe
Apr 12, 2015 12:25 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
LT1runner
33
Jul 24, 2002 01:19 PM
