Looking for pulley change method on Procharger..
Old Oct 30, 2006 | 11:49 AM
MattSLONOMO's Avatar
doing a pulley swap for the 1st time and can't find any info on the R and R method..
my Procharger D1 (sc) for the LT F-body manual has 'no' info..
would love to know the torque specs, tips, tricks or special tools before I dig into it.
Thanks Ahead!
Matt
Old Oct 30, 2006 | 01:56 PM
KS91Z28's Avatar
There are no special tools, or torque specs. Just loosen the bolt in the center of the pulley, loosen the belt, then pull the pulley off the blower. If it doesn't slide off easily, just heat up the pulley with a propane torch. The pulley will expand and then it should slide off pretty easy. Put the new pulley and belt on, then tighten the bolt as tight as you can get it by hand, or hit one quick time with an impact.
Old Oct 30, 2006 | 02:01 PM
Sparkz28ss's Avatar
What he said....heat is your friend....just be smart about it
Old Oct 30, 2006 | 05:31 PM
Thanks Loads Guys!
Matt
Victor Lamb
Aug 26, 2017 02:52 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
jasonduaine
Mar 7, 2015 09:44 AM
