Leaking front seal: ATI big block damper
Guys,
I'm having a little trouble with a leaking front seal on my car. I'm wondering if any of you have found a better quality seal than the typical napa seal that is recommended. This is my second leaky front seal in less than a year. The second time I polished the surface with 400 grit sandpaper and used wheel grease on the seal. It failed too. Any ideas.
This is the ATI "big block" hub that is designed for blower applications and requires machining the front cover for a bigger than stock seal.
Skull Leader
Aug 10, 2002 11:01 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
